Need help on beefier tire sizes...
Old Mar 18, 2013 | 03:17 PM
McFab's Avatar
Default Need help on beefier tire sizes...
So i've been tire shipping lately and want to go larger in the front and rear, but I dont know a thing about tiring sizing and fitment. I figured some of the wheel gurus out there could lend me a hand.
Specs are 18x8 +42 in the front and 18x9.5 +36 in the rear. The current tires are Falken 452, 215/35/18 and 245/35/18. Looking to add some more rubber onto my wheels, the stretch is too much for me, I like the meatier look.
Old Mar 18, 2013 | 03:43 PM
1nate7's Avatar
Next logical step is 225/40, 255/35.
Old Mar 18, 2013 | 03:47 PM
s2000Junky's Avatar
Agreed.
I just don't see you adding much more tire with those wheel specs beyond 225/255. Outer fender clearance is holding you back as I'm sure you can visually see some indication of.
Old Mar 18, 2013 | 04:25 PM
McFab's Avatar
Originally Posted by s2000Junky
Agreed.
Ya absolutely. In the future I will be re-lipping my wheels and going with downforce fronts and asm rears, but until then I'm gonna just throw some new rubber on and tackle that project next winter.
I'd really like to add these beefier tires on and add spacers all the way around. 20mm front and 10mm out back
Old Mar 18, 2013 | 05:01 PM
Manga_Spawn's Avatar
Site Moderator
Thats going to be tough even this the widebody stuff. Anything is possible but it won't be easy.
On your current set up get a 225 and 255 and go with something like an RS3 that runs wide and you will get the look and performance you want.
Old Mar 19, 2013 | 11:33 AM
Jim@tirerack's Avatar
Former Sponsor
With those wheels you are going to need more negative camber and a fender lip roll to make them fit without rubbing.
Old Mar 19, 2013 | 11:50 AM
McFab's Avatar
well i'm rolled almost flat in the rear and have -3.3 camber in the rear and -2 up front if i remember correctly. the fronts arent rolled tho.
Old Mar 19, 2013 | 01:30 PM
jwr0ng626's Avatar
The reason you don't have beefier tires now is because your wheel specs are too aggressive. You'll run out of less usable tire space(width) by using spacers too. I don't see running beefier tires + spacers being possible without fender mods first.
Old Mar 19, 2013 | 02:14 PM
Site Moderator
Man does anyone read? He already talked about doing some widebody work for the spacer/widening of the wheels. Do the sizes recommended and get a tire like an rs3 that runs wide and you will be happy.
warbucks
Official "Official" Forum
Mar 17, 2013 02:10 PM
JS2k.com
Jul 15, 2009 08:19 AM
jmrobins
Mar 29, 2009 06:31 PM
Shvitz2k
Mar 25, 2004 08:44 PM
AndyP
Apr 28, 2003 02:12 PM
