need help with camber???
Old Feb 28, 2003 | 03:49 PM
laos2000's Avatar
Default need help with camber???
new to this, just bought a used s2000 01 from somebody. notice that the back wheels has a negative camber, was wondering if that was normal? any replies would be very appreciated.
Old Feb 28, 2003 | 04:24 PM
00S2K01S4's Avatar
Even stock, the S2K has some pretty negative camber already. If you are worried, I would get an alignment.
Old Feb 28, 2003 | 11:42 PM
Schatten's Avatar
correct, the stock alignment in the rear has about -1.1 degrees. I always recommend about 2 degrees in the rear which is a bit more aggressive than that.
if you do highway driving and no track/autocross/road course events, you can get away with ~-1.1 degrees. however, the handling will not suffer, but will not be as great.
as you know the tires cannot be rotated, so you'll just have to watch wear every so often. but in the end, its a sports car, and meant to be driven like one. =D
Old Mar 1, 2003 | 12:19 AM
Q8Boy's Avatar
I have lowered my car with HKS lowering spring, I would like to ge the negative camber adjusted...who makes camber kit for S2000. I did the search but didn't find nothing. Any help please. Thanks
Old Mar 1, 2003 | 12:28 AM
Schatten's Avatar
there is no camber kit for the S2000.
the fronts are a shock suspension. typically camber kits are for strut-style suspensions.
not sure how low the HKS springs bring the car down, but in cases where it was lowered more than 1.4"s - you won't be able to get anything more positive than say... -2.2 in the rear.
kandyred
Jul 27, 2013 07:53 PM
JAYRS2000
May 28, 2012 12:57 PM
Flapjack
Mar 29, 2011 10:42 AM
s2000nubi
Dec 22, 2005 11:06 AM
efthimios
Nov 2, 2003 08:58 AM
