Need help fast! about offset on 19's
Old Dec 8, 2008 | 09:24 AM
SSBullet's Avatar
Default Need help fast! about offset on 19's
I am looking to buy some 19 by 8.5 wheels for the front and I do not know much about wheels so I need your help. What kind of offset do I need on the wheels. The guy I am buying it from says i need 40. I am planning on putting 235/35/19's on it if that helps. I tried searching but couldn't find anything.
Old Dec 8, 2008 | 11:32 AM
s2killa's Avatar
it dont matter what size the diameter is ie: 16", 17", 18" and so on, the offset will not have an effect on that... for an 8.5 look for something around a 45-50... anything higher will require less modification if none at all, anything lower might require fender rolling or negative camber...
also, u plan on putting a 235 on an 8.5" tire all around??? do u just plan on having this car for looks and looks alone??? i think u need to do some more research... and i think a 235/30 would be the correct choice...
Old Dec 8, 2008 | 05:12 PM
BSeriouS's Avatar
This all depends on if any mods have been done to the fender ie:
roll, pull, trim, cut etc etc.
If these have not been done, you will rub, of course this depending on your height
Old Dec 8, 2008 | 05:56 PM
SSBullet's Avatar
I am on stock suspension and springs. The rear wheel is a 19 by 10. Planning on going 275/30/19 on the rear and 235/35/19 on the front. I haven't gotten anything done to my fenders. So does that mean the 40mm offset is too big? Thanks for your help
Old Dec 8, 2008 | 06:08 PM
Js S2k's Avatar
no 40mm offset is too small.
Wheel Fitment Guide
https://www.s2ki.com/forums/index.php?showtopic=342793
It says a 58 but you could get away with a +55mm offset without having to modify anything.
"235 tires: +58 offset minimum (7.5
Old Dec 8, 2008 | 06:29 PM
BSeriouS's Avatar
+40 is way to low, that is if you do not have any of the proper fender mods.
If you want to keep your fenders untampered and run tire sizes that big, you have have to ante up the offset to +65 and up.
BLACKBRIAR
Aug 3, 2014 01:09 PM
youngjae
Nov 3, 2009 05:23 AM
gpwhite99S2K
Sep 2, 2006 09:02 AM
xda2000
Jun 29, 2004 11:07 AM
amongmany
Aug 27, 2003 02:46 PM
