Need help removing lug bolts
Old Dec 9, 2005 | 05:19 PM
ncspyder's Avatar
Default Need help removing lug bolts
I need to remove the lung bolts to install longer bolts (for wheel spacers). Is there a tool or technique for removing the lug bolts without damaging the hub (i.e. I don't want to hit it them with a hammer)?
Old Dec 12, 2005 | 09:41 PM
eraxpres's Avatar
spray them down with PB Blaster and let it soak overnight and just use a rubber mallet the next day
Old Dec 13, 2005 | 04:18 AM
spa-zz's Avatar
Does the knuckle or brake dust shield get in the way of removing the studs?
Old Dec 13, 2005 | 12:00 PM
spoiled@21's Avatar
i'd like to know the easy way to remove the studs as well.
Old Dec 13, 2005 | 04:57 PM
spa-zz's Avatar
https://www.s2ki.com/forums/index.php?showtopic=331031
also
https://www.s2ki.com/forums/index.php?showtopic=243364
https://www.s2ki.com/forums/index.php?showtopic=255268
https://www.s2ki.com/forums/index.php?showtopic=318112
Unit00
Mar 6, 2017 01:52 PM
lopez14
May 11, 2012 11:29 AM
ncspyder
Dec 31, 2005 01:18 PM
