Need offset and tire size for 18
Old Jan 13, 2003 | 01:17 PM
jtem's Avatar
Default Need offset and tire size for 18
I am looking for the correct offset and tire size for 18x7.5 and 18x8 also i have a 1.5 drop
Old Jan 13, 2003 | 02:41 PM
Unicron's Avatar
With 18x7.5 you will need at least +50mm. I would go for +55mm.
225/40/18 (25 inch diameter) works pretty good with a 18x7.5 wheel. 215/40/18 (24.8 inch diameter) works also, but the ride is harsh and that tire size is pretty rare.
18x8 is not that great of a size for the rear. Mainly because it is recommended not to go above 245/35/18. You want the option to run 255/35/18. Get at least 18x8.5...I like 18x9.
18x8.5 - 60mm
18x9 - 65mm
These offsets are tough to find...and alot of wheels will push the limits. For example, I am running:
18x7.5 +48mm, 225/40/18, toyo t1-s
18x8.5 +50mm, 255/35/18, es100 yokohama
I think I have about an inch drop...dunno, I am using the comptech coil overs. But I will tell you that I rub sometimes in rear when I am driving fast over some dips in the road.
Old Jan 19, 2003 | 03:39 PM
ScottyBallistic's Avatar
I am also having wheels made in 18"
so if I went 18X8 +55mm and 18X9 +65mm I should have no issues with a 1" drop
Old Jan 20, 2003 | 07:31 AM
Jim@tirerack's Avatar
Former Sponsor
Twiztid,
Your sizes would be fine. If I can help with the tires let me know.
Jim 800-428-8355-364
Old Jan 20, 2003 | 07:34 AM
Former Sponsor
jtem,
You can use either 18X7.5 or 18X8 in the front with anywhere from 48 to 55mm offset no problem. I also would recommend a 18X9 rear to allow for the 255/35R18 tires. You will find more options in this tire size. The offset would be somewhere around 55 to 65 mm offset.
If I can help let me know.
Thank you
Old Jan 20, 2003 | 09:10 AM
jtem's Avatar
jim,
what tire size should i use if i want to put the 18x8 on the rear.
Thanks
Old Jan 20, 2003 | 04:20 PM
Thanks Jim
Old Jan 29, 2003 | 07:10 PM
revhi's Avatar
What rims are those Unicron?
Ive been looking for Volk Te-37s in a gunmetal with a polished lip, Ive seen them in magazines on other cars but cant find them.
Does anyone know of another rim similar to that?
Old Jan 30, 2003 | 06:49 AM
jtem's Avatar
Try the LE37s by Volks and they make a gunmetal w/ polish lip
DangerZone9K
May 27, 2012 06:01 AM
lastminute_s2k
Jul 14, 2009 07:39 AM
NCTUAN03
Apr 20, 2009 01:25 PM
oompa611
Jan 30, 2005 08:37 PM
78roadrocket
Jul 15, 2004 07:30 PM
