non stagger question
Old Nov 23, 2013 | 09:15 AM
krosfyah01's Avatar
Default non stagger question
Just wondering how much work is involved in running this setup? From what I've read so far I'll definitely need to roll the rears but still not sure what the fronts will need.
I ordered a set of wedssport tc105n's and would like to run 255/40/17 all around.
Current suspension setup is bilstein pss9's.
Old Nov 23, 2013 | 09:28 AM
Rays S2k's Avatar
What are the specs on the wheels
Old Nov 23, 2013 | 10:03 AM
ryuken's Avatar
Here is a pic. The front fender is pulled. https://www.s2ki.com/s2000/topic/669...t__p__15361442
Old Nov 23, 2013 | 10:42 AM
s2000Junky's Avatar
If the rims are the exact same dimensions as well as tires, you can always plan on needing to do more work up front to fit. If the rears need rolling, you can pretty much plan on needing to do that plus pulling up front.
Old Nov 23, 2013 | 02:03 PM
krosfyah01's Avatar
17x9 +49
Old Nov 23, 2013 | 02:05 PM
Rays S2k's Avatar
Originally Posted by krosfyah01
17x9 +49
All you need is just rolled fenders
Old Nov 23, 2013 | 02:07 PM
krosfyah01's Avatar
Oh wow, I thought didn't think it needed that much work. Any more pics of that car?
Makes sense
I thought I was going to get away with a fender liner trim up front, roll the rear and relocate bumper tab. I don't plan on going that low anyways, most likely leave a finger gap and have camber down to -3
Old Nov 23, 2013 | 11:14 PM
Manga_Spawn's Avatar
Site Moderator
Still need to roll the front. The fender liner doesn't matter at all. If fact if you trim that and don't roll your fenders you are actually in more danger since the fender liner stops the tire from grabbing the fender for a little while in this scenario. If that's not there it's just tire against fender if you aren't rolled and it will do damage. Roll all the fenders and you can probably avoid any pulling if you run more camber like you are planning.
Old Nov 25, 2013 | 06:16 AM
Sebring AP1's Avatar
Just rolling on both ends is fine. With -3 camber it won't take a lot but you really want to roll as much as you're okay with to avoid catching the lip during spirited driving. NOTHING is more irritating than a pulled fender that has been damaged because the clearance wasn't sufficient.
Old Apr 1, 2014 | 07:25 PM
krosfyah01's Avatar
Got some additional questions for the guys running the same setup or even similar
Are you running adjustable ball joints or would the stock ones be sufficient enough for my setup.
I didn't realize when I said that I'll be going with a -3 camber that the stock ball joints will max out around -2.
Going to get the alignment done as soon as the car comes out in May.
