not running staggared
Old Jul 10, 2006 | 09:17 AM
kaylins2k's Avatar
Default not running staggared
will not running starraged be dangerous?...im was thinking 17,7.5 fornt and rear.. beacause the rims i want dont come any wider for the rear, any input will be great
Old Jul 10, 2006 | 09:33 AM
xviper's Avatar
It only becomes dangerous if you think the car will handle the same. If you realize the new handling limits of the car as a result of using such rims and tires and drive accordingly, no biggie. Almost anything you do to any automobile will changes it's handling characteristics. Understanding what those changes are will keep you and the car safe. However, if you drive it like you did before, then yeah, it becomes dangerous.
Old Jul 10, 2006 | 12:28 PM
kaylins2k's Avatar
gotchca, thanks for the feedback
Old Jul 10, 2006 | 12:32 PM
wantone's Avatar
xviper!
Old Jul 10, 2006 | 01:20 PM
xviper's Avatar
Originally Posted by wantone,Jul 10 2006, 02:32 PM
xviper!
Hey, bud! Miss ya. Where ya been?
Old Jul 10, 2006 | 01:56 PM
wantone's Avatar
Just came back from HK/Singapore! My PM's are too full!!!
Old Jul 10, 2006 | 11:56 PM
AP2's Avatar
AP2
plus you can rotate your tires...
Old Jul 11, 2006 | 05:55 AM
dmw16's Avatar
What kind of handling changes should someone expect?
Old Jul 11, 2006 | 06:18 AM
DerrS2K's Avatar
Much more oversteer
Old Jul 11, 2006 | 06:42 AM
xviper's Avatar
We must talk about this from 2 perspectives. Are you still running staggered tires or are you not?
If you still run the same sized tires all around, then as Derr posted, you will increase the tendency to oversteer due to the smaller rear contact patch compared to the front.
If you remain with staggered tires, you will be doing one of 2 things (depending upon the width of rim you choose) you will be stretching the narrower tire out onto the rim and you will be pinching the wider into the rim. Not only will you have to alter the tire pressures to maintain an even contact patch, but you will have a spongier feel on the tire that is pinched due to more sidewall flex and reduced tire pressure.
If you go with the 7.5" rim width like in your first post and go with the stock tire confirguration (215 front and 245 rear) then the fronts will be fine (just like stock) and the rears will be "pinched".
