NOTICE: Correct Rear Tire Size AP1
Hmm, I always was told, and figured, that sidewall numbers were measured height. I think I measured myself once and it proved correct... Maybe not. *shrug*
As far as the width goes..... I know it's edge-to-edge, but again, I was giving him a simple explanation.
golfnut, yer welcome.
-S2-
-S2-
If the difference between the stock OEM PP and "street" PP were factored in, I believe the Nitto would still be putting down more tread.
the OE tire IS NOT a PP (Pole Position) - a 225/50/16 SO-2 Pole Position is NOT the tire that came on the car - the car came with non-Pole Positions that are about the equivalent of a 245.
if you were to compare a PP S)-2 and the OE SO-2 in 225/50/16 - they would physically be different widths (i.e. measured width)
bridgestone makes both a PP and non-PP version (maybe not anymore, but they used to)
don't compare the nitto or any other tire to a SO-2 PP in like sizes.
someone chime in if they think i'm mistaken....
[QUOTE]
Originally posted by Russ
Again, as I have stated in other posts, careful attention has to be paid to the specific tire you are comparing the SO-2 with. What makes the SO-2's width (contact patch) wider than its stated size is the construction, and this applies to other tires as well. A Nitto NT-555 reportedly has the largest contact patch of any "ZR" rated tire, so switching to that tire will not result in the differences (225 to 245) you mention above.
[QUOTE]Originally posted by cdelena
[B]
[QUOTE]
Originally posted by Russ:
My point was to inform some of the newbies that Bridgestone is not the only company that makes a "wide" version of an applicably sized tire.
[B]
[QUOTE]
OK Phantom, now you confused me (I think). Having always just gone to the tire stores and said ..... Replace my tires, I never gave tires a thought until getting this wonderful car. Now, you post the following:
"225/50/16 SO3's have a tread width of 8.3 inches on a 7 inch wheel.
245/45/16 S03's have a tread width of 9.1 inches on a 8 inch wheel.
225/50/16 S02 (stock) have a tread width of 8.5 inches on a 7 inch wheel."
Again, being totally ignorant on tires, how can a 245/45/16 SO3 with a tread width of 9.1 inches on a 8 inch wheel fit on a 7 inch wheel?
What am I missing? Kind of like putting 10 pounds of stuff in a 5 pound bag, at least it sounds like it to me.
Obviously, I am missing something here, so could you explain?
Thanks.
Thanks.
