Nt03+m 17x9.5 Hyper Black offset
I'm currently considering buying a set of NT03+Ms in 17x9.5 in +44 offset. I would much prefer them in hyper black/hyper silver as apposed to plain silver; however, judging by my own research it seems the +44 offset at this size is only offered in silver. Can anyone confirm that this is the case? If it is, would the 6mm offset difference cause significantly more fitment difficulties than the +44? (I'll be lowering probably no more than an inch and of course be rolling fenders and relocating tabs.)
yes, +38 will be a much more difficult fit vs the +44.
If you're planning on tracking the car with 255 square (which it looks like based on your sig), go with the +44. Even then you'll have to work the front fenders a bit. ShaneG in SoCal should be able to help you out with that.
Yeah how do you figure? There some measurable data on this? Not that it really matters to me at this point since ive clocked about 150k miles on my set. If a cut and welded/widened rpf1 will support my 255/295 wide stagger with extreme summer level adhesion on the road course and many thousands of DD miles, its good enough for me! I will gladly take the weight savings benefits for my application. Having a staggered concave/convex face also gives me the look I like with any BBK clearance up front.
