S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   Odd problem (https://www.s2ki.com/forums/wheels-tires-56/odd-problem-599195/)
mlc May 24, 2008 07:56 AM
Odd problem
I just looked at my right rear tire and it was every low 7.5 lbs. I took it off and did not see any obvious problem. I have filled it back up and will keep an eye on it. if it goes flat again I will bring it somewere to have it looked at.
Here is my problem. I am running Potenza RE750's and they are fairly new. I bought the car with them on it but they can't have more the a couple of thousand miles on them.
So if I do need to replace the tire you can't get the RE750's any more. Should I just replace both back tires and keep the left one for emergences.
If I do decide to do that I would stay with Potenza'a to at least have the same manufacterer on the car.
I was looking at the RE760. Has anyone run these and if so what is your opinion of them.
Also I know there are different tread width's for tires. I looked on Tirerack.com and the 760 has a Tread width 8' and the 750 is 7.2". Is the 760 closer to the OEM spec tire?
Thanks in advance for any help.
mlc
AP2 May 25, 2008 05:20 PM
i would just replace both rears if that one tire is not repairable.
Jim@tirerack May 28, 2008 04:51 AM
I agree. Have the tire checked and if it can not be repaired I would replace the two ties with the RE760. They are the most similar tire with better handling that the RE750.
If I can help let me know.
AP2 David May 28, 2008 05:37 PM
:iagree:
cannonball May 29, 2008 07:41 AM
Could be a slow leak due to a valve stem problem.
Jim@tirerack May 29, 2008 07:54 AM
A tire store can try to figure it out for you. They can put the tire in a dunk tank and look for the leaks.
© 2026 MH Sub I, LLC dba Internet Brands
