Odd problem
Old May 24, 2008 | 07:56 AM
mlc's Avatar
mlc
Default Odd problem
I just looked at my right rear tire and it was every low 7.5 lbs. I took it off and did not see any obvious problem. I have filled it back up and will keep an eye on it. if it goes flat again I will bring it somewere to have it looked at.
Here is my problem. I am running Potenza RE750's and they are fairly new. I bought the car with them on it but they can't have more the a couple of thousand miles on them.
So if I do need to replace the tire you can't get the RE750's any more. Should I just replace both back tires and keep the left one for emergences.
If I do decide to do that I would stay with Potenza'a to at least have the same manufacterer on the car.
I was looking at the RE760. Has anyone run these and if so what is your opinion of them.
Also I know there are different tread width's for tires. I looked on Tirerack.com and the 760 has a Tread width 8' and the 750 is 7.2". Is the 760 closer to the OEM spec tire?
Thanks in advance for any help.
mlc
Old May 25, 2008 | 05:20 PM
AP2's Avatar
AP2
i would just replace both rears if that one tire is not repairable.
Old May 28, 2008 | 04:51 AM
Jim@tirerack's Avatar
Former Sponsor
I agree. Have the tire checked and if it can not be repaired I would replace the two ties with the RE760. They are the most similar tire with better handling that the RE750.
If I can help let me know.
Old May 28, 2008 | 05:37 PM
AP2 David's Avatar
Old May 29, 2008 | 07:41 AM
cannonball's Avatar
Could be a slow leak due to a valve stem problem.
Old May 29, 2008 | 07:54 AM
Former Sponsor
A tire store can try to figure it out for you. They can put the tire in a dunk tank and look for the leaks.
S_special
Oct 17, 2008 05:59 AM
mew002
Jun 4, 2008 03:24 PM
marshall
May 16, 2005 02:40 PM
watchyosix
Jun 1, 2004 07:43 AM
gbaker
Jan 22, 2002 01:51 PM
