Off-set help!
Old Apr 21, 2008 | 09:04 AM
KaNgArOo's Avatar
Default Off-set help!
Just wanted to know if I would rub if I don't roll my fenders.
Car is droped on KW V3 suspension.
I want to get the SSR Sp1 in.....
front
18x8 +68 offset....or is it better (18x8.5 +55)
rear
18x9.5 +68 offset or could I do (18x10 +62)
Which combo would fit with out rubbing??
Also for tires.
225/40/18
255/35/18 or 265/35/18???
I don't really feel like rolling the fenders and just want to know if I will rub at all??
About to order from Gruppe-s.com
Just want to make sure the wheels will fit good.
Thanks..
Old Apr 21, 2008 | 09:38 AM
KaNgArOo's Avatar
ANyone??
Old Apr 21, 2008 | 01:00 PM
bullitt5897's Avatar
what is your goal?
1. get as much rubber to the ground?
2. bragging rights to wheel size?
3. clean look?
4. performance?
these will help you figure out what size you want to run...
Camber can fix some of the sizing issue but you have to understand the more camber you run the more you compromise your performance possibilities!
I will be running 18 x 9 +40 and 18 x 10 +37 this is going to require alot of camber for me as well as rolling fenders.
let us know what your goals are and we can better help you
Mike
Old Apr 21, 2008 | 01:01 PM
18 x8.5 should be fine with a 225 tire
18 x 9.5 should be fine with a 255 tire
Old Apr 21, 2008 | 02:31 PM
KaNgArOo's Avatar
Thanks Mike.
I want a clean look with a lip.
Just wondering which exact off-set and width would work best.
Old Apr 22, 2008 | 12:57 PM
KaNgArOo's Avatar
So
18x8 +62 offset 225/40/18
18x9.5 +68 offset. 255/35/18
THese are what I'm going to get....
Old Apr 25, 2008 | 12:11 PM
KaNgArOo's Avatar
Update....Just ordered SSR SP1
18x8 +49 offset
18x9.5 +55 offset
Going to get tires....in size
225/40/18
255/35/18
I think I'll have to roll my fenders.
LuvNdaVtec
Mar 24, 2018 11:55 AM
smokinpeanuts
Sep 18, 2012 09:16 AM
nightowl
Mar 7, 2011 05:43 PM
Jo2
Jan 17, 2007 05:16 PM
ChopperDave
Oct 22, 2004 07:25 AM
