offset and j
Old Mar 26, 2005 | 11:41 PM
S9735's Avatar
Default offset and j
i'm gonna buy 17'' wheels for my 03' s2k
the front ones are 17"x8j and the rear ones are 17"x 9j
can the 04' stock tires sizes (F 215/45 R 245/40) fit them?
and what is the proper offset?
Will it be ok if the front is +45 and the rear is +63??
plz do me a favor you adept guys..
Old Mar 27, 2005 | 06:08 AM
wing's Avatar
That offset should be ok, not sure about the tire size 9" is a little wide but 245 should fit on them, you might need 225 to fit the front rim.
Old Mar 27, 2005 | 10:46 AM
Batbite's Avatar
FRONT - don't run the 225 wide tire..........especially if you are going to lower the car.....you'll rub (a lot)........you can get by with running a 215/45/17 in the front but the offset of +45 is a little low.
REAR - the offset that you have listed is great for the 9" wheel +63.... ..................you should be running a 255/40/17. This will fit perfectly....no issues lowered or not.
good luck....!!
Old Mar 27, 2005 | 11:35 AM
S9735's Avatar
THANK YOU GUYS
that's what i wanted to know
so glad to hear everything is fine
by the way...could you tell me the specifications of the 04' OEM rims?(j number & offset)
Old Mar 28, 2005 | 12:24 AM
S9735's Avatar
push
S1LV3RS2K
Apr 23, 2008 06:45 AM
iNetForce
Apr 22, 2006 05:20 AM
vroooom247
Jul 30, 2005 02:32 PM
Ubetit
May 21, 2005 09:06 AM
Jaydem
Dec 14, 2004 09:44 PM
