Offset question
Old Jan 23, 2014 | 09:30 AM
Pastor's Avatar
Default Offset question
Hey guys I have a quick question, im no wheel guru, that and i have a terrible memory so those two combined led me to the situation im in. I started my project S years ago, and long story short it didnt go as planned and now i'm picking it back up again 3 years later. I ordered some wheels for the project, but forgot what mm over fenders i was going to get for the rear, and what mm wide fenders i was going to get for the front so i was hoping someone could help me out here so i can order the right fenders and get on with it. The wheel specs are:
17X10 +44 w/1.5 inch lip in the front
17X11 +25 w/3 inch lip in the rear
The wheels are ccw classics
If you need anymore information to help me out i have the original work order for them.
Old Jan 23, 2014 | 09:55 AM
s2000Junky's Avatar
You didn’t list what width tires you were planning to run. That will have an effect on fitment. So I will assume since these are 17" you are going with 255/40 up front and 275/40 in the rear. Its the only size that really makes sense for these wheel widths ( unless Kuhmo XS replacement brings back the 295/35/17)You can run that for the rear. It’s the stagger I have now.
You will need at minimum an additional 35mm of fender for the rear. +40 would be better (if you can find it)
You will need at minimum 15mm for the front fenders (should be no problem)
Old Jan 23, 2014 | 10:00 AM
Pastor's Avatar
Im still up in the air about tire width, since i was trying to find a 295, but what you meantioned was what i was leaning towards. Thank you for your help brother i appreciate it.
Old Jan 23, 2014 | 10:54 AM
s2000Junky's Avatar
No problem.
I should note, If 295/35/17 becomes available again this summer with the new V720 and you want to rock them, you will need to increase your rear over fenders to another 10mm over what I stated, to be able to accommodate them. Unless you go custom fenders or re barrel your wheels for a higher offset or get lucky and find some bolt ons that are +50mm, you will be hitting on the outside still with those tires.
Old Jan 23, 2014 | 11:25 AM
Pastor's Avatar
Originally Posted by Pastor' timestamp='1390503613' post='22979737
[quote name='s2000Junky' timestamp='1390503328' post='22979720']
No problem.
[/quote]
Thanks for the info. With the price of fenders as it is, i might as well go custom fenders to be honest.
always@9k
Nov 17, 2011 06:12 AM
red93.5mkiv_tt
Jul 15, 2008 05:45 PM
502ap1
Apr 21, 2008 02:03 PM
RuRoUni_SS
Feb 25, 2008 11:55 PM
