Offset Question
Old Jul 20, 2009 | 03:37 PM
SebRedAP1's Avatar
Thumbs up Offset Question
Hi I am new to the whole S2000 scene/honda scene in general. I used to own several VWs and the offsets are totalllyyy different. I have been doing some research on what offsets work and which dont. I am looking for more of a low offset / aggressive look. I do not track my car at all, its a daily driver.
I have been eyeballing this set of BBS LMs but I dont think the offsets / widths will work.
17x9+35 17x10+50 5x114.3 I am pretty sure the front offsets are too low.
I have also been looking at a set of BBS RSs.
These for example are 17x8+45 17x9+53, but I would most likely refinish them and buy bigger lips that would make the final widths 17x9+45, and 17x9.5/10 +53.
Any opinions would help, I am going to be buying wheels first, then coils because I will refinish either set of wheels with a custom color.
Old Jul 20, 2009 | 04:12 PM
Vik2000's Avatar
LMs will work but require fender pulling and more neg camber. Not a big fan of RSs. Must be PITA to clean. What do you mean by "buying bigger lips"...?
Old Jul 20, 2009 | 04:37 PM
SebRedAP1's Avatar
They are 3 piece wheels, and you can source different sizes of lips ranging from .5" to 3". You can also find 4" lips but they are a PITA to find. on the 17x9 I believe the lips are 1.5" wide, and I would buy lips that are 2.5" or 3" and make them 17x10/10.5. Put the 1.5" lips on the 17x8s which are only 1" and make them 17x8.5. Or buy 2" lips and make them 17x9.
Would it require pulling or just a roll with a fender roller? I dont mind stretched tires. I already planned on running -2 or -3 up front and -3 or -4 rear as far as camber goes.
Old Jul 20, 2009 | 04:48 PM
Vik2000's Avatar
I believe pulling is necessary for 9 width. +35 is pretty low. On stock fender, you'll need pulling and perhaps at least -3.5 camber. Probably some expert can confirm.
But seriously, it's really doable and I've seen many who've done it.
Old Jul 20, 2009 | 04:55 PM
SebRedAP1's Avatar
How much would it cost to get fenders pulled at a body shop? Can it be DIY without paint damage or what? And would it require front and rear fender pulling.
Old Jul 22, 2009 | 11:27 PM
[DPK] P1E's Avatar
Just make sure you don't buy from RB and end up with some cracked wheels with a poor weld job =(
Not to mention warped wheels that they'll hang up on you for if you try calling about it..
Old Jul 23, 2009 | 01:23 AM
chilicoke's Avatar
I'm running 17x9 +35 with 255 RE01Rs on all four, front fenders need to be flared and anything can be DIYed (check sig ) but not without repaint.
17x10+50 will work in the rear, in fact the outside lip will sit 2mm further into the body compared to 17x9 +35. Check my fender thread, I have pictures of all the necessary cuts/mods and alignment specs needed to make rear fit.
PM me if you need any more details.
Old Jul 27, 2009 | 12:27 AM
SebRedAP1's Avatar
up
GizmoPhoto
Mar 21, 2016 10:10 PM
SuperSaiyan
Mar 7, 2014 06:29 PM
Zuko
May 8, 2011 03:50 PM
Yatzee
San Diego S2000 Owners
Sep 15, 2007 05:44 PM
dave22
Jul 22, 2003 06:07 AM
