Offset & Tyres Questions
Old Aug 12, 2007 | 08:52 AM
3r1k's Avatar
Default Offset & Tyres Questions
Will 17x8 +45 and 17x8.5 +40 fit s2000 w/o any rubbing issues?
If there won't be any issue, what tyre size should I fit in those rims
Thanks
Erik
Old Aug 12, 2007 | 09:36 AM
raskell's Avatar
Please note the first 'Sticky' post at the top of the page:
"For the front:
6.5
Old Aug 12, 2007 | 09:47 AM
3r1k's Avatar
Thanks for the heads up.
I'm just asking because I can get these set of rims for cheap although the offset might not be right for the car.
Old Aug 12, 2007 | 10:17 AM
kushs2k's Avatar
roll your fenders and run 215/245 tires depending how low you are you shouldn't rub if it does just dial in some camber
Old Aug 13, 2007 | 01:26 AM
3r1k's Avatar
Mmmm I will be running stock suspension and -1 front camber, will it still rub?
Old Aug 13, 2007 | 04:16 PM
captnplnet's Avatar
if you dont roll the rear fenders you might still rub on large bumps/dips. However im not sure if you will at stock height. if you plan to lower the car ever, you should definitely roll at least the rears.
Old Aug 14, 2007 | 06:48 AM
North Star's Avatar
The guide above is for ideal fitment with no necessary alterations to fenders and/or camber. I believe the OP will be fine running those wheels with a 215/245 set up on stock height.
Old Aug 14, 2007 | 08:27 AM
captnplnet's Avatar
^ sounds good. my car hasnt seen stock height in i dont know how long
to the OP, what wheels are you getting?
Old Aug 14, 2007 | 10:04 AM
North Star's Avatar
That's the reason why I haven't done my wheel project yet. Gotta get a drop first and foremost!
Old Aug 14, 2007 | 09:39 PM
3r1k's Avatar
What is an OP? LOL
Beware: noob alert
