ok to downgrade in speed rating?
Old Jan 3, 2003 | 11:42 AM
mr tl's Avatar
Default ok to downgrade in speed rating?
my car came with V rated tires, im thinking of downgrading to H rated.
is this wise, assuming all other specs are equal/better?
i'll never hit the H top speed
thanks
Old Jan 3, 2003 | 12:25 PM
Schatten's Avatar
depending on how you drive, you'll feel a difference. the lower the speed rating - generally - the harder the tire, and thus... less likely to grip. but if this is for the TL, H's should be that much of a problem.
Old Jan 4, 2003 | 07:21 AM
psyco6string's Avatar
If Your suspension is tuned for the higher speed rating ,you should stick to specs or better, downgrading is normally a bad thing !!Stiff suspension can overwork a wimpy sidewall .
Old Jan 4, 2003 | 09:25 AM
Jim@tirerack's Avatar
Former Sponsor
Depending on the car and how you drive the H speed rated would be fine. If you are an aggressive driver I would not recommend it . If you are looking for more ride quality and longer tread life you can normally get that with the H speed rating.
If I can help let me know.
Thank you
Jim 800-428-8355-364
gaus
Apr 15, 2009 04:48 AM
Mattyboyz
Sep 25, 2006 10:49 AM
GSi
Nov 4, 2004 07:29 AM
dolebludger
Dec 5, 2003 08:07 PM
ReedZ
May 13, 2002 09:06 AM
