Please, alignment help.
Old Mar 10, 2009 | 05:55 PM
pistolpete17's Avatar
Default Please, alignment help.
I have a new set of RE-01R coming and I'd like to get some advise on alignments. I searched, and have become even more confused. Any info is appreciated.
MY07 stock. Driven hard but not tracked. Best alignment? (also, what are stock specs?)
Old Mar 10, 2009 | 10:00 PM
ilaggoodish's Avatar
check this post
a lot of good info
https://www.s2ki.com/forums/index.php?showt...light=alignment
https://www.s2ki.com/forums/index.php?act=m...image&img=12060
Old Mar 11, 2009 | 03:13 AM
INDYMAC's Avatar
The alignment specs are listed in your owners manual near the back under "specifications". These specs are good to go for your needs. The shop will probably have the specs for your MY07 in their software, but it's good to have them available just in case. Make sure that you sit in the seat while they align the wheels. Have them align everything exactly to specs, not just within limits. Have them re-torque the locking bolts to 58lbs. You don't want anything loosening up after the alignment. If you can't be available to sit in the seat, have them add enough dummy weight to your approximate weight in the seat.
I just went through this yesterday at my local shop with my new RE-01R's. It cost $69.95, so plan to take enough money with you.
Old Mar 11, 2009 | 08:55 AM
Thanks.
Old Mar 11, 2009 | 09:52 AM
nr7's Avatar
nr7
go to firestone. they have life time alignment for cheap. i believe they have newest machine. go online and print 10$ 15$ off coupon. i already did twice within two months. and also u can do alignment any firestone in US. correct me if i'm wrong abt firestone.
Old Mar 11, 2009 | 10:18 AM
Thanks. Just called and they will not align with anyone in the car.
Old Mar 11, 2009 | 11:20 AM
you dont need to sit in the car to get an alignment.
corner weight does =)
Old Mar 11, 2009 | 01:40 PM
I've heard different. And seen different. Working for BMW, saw and talked to guys in the shop who (per BMW) had to load up a car with weights when it was aligned.
No, I have not seen how the specs change, but I believe they do. Also, I believe the lighter the car, the greater the difference.
just my $.02
Old Mar 11, 2009 | 01:46 PM
My MY07 manuel reads:
Toe
F 0.00
R 0.15 in (3.7 mm)
Camber
F -0 deg 30'
R -1 deg 30'
Caster
F 6 deg
Old Mar 11, 2009 | 02:13 PM
s2kfrog's Avatar
Those caster settings are basically at the max so you do not need to worry about adjusting that a differently.
Start with base, then go by feel. If your car is a little too tail happy for you give it a bit more toe-in on the rear. Maybe more negative camber in front and rear if you plan to track your car or do a lot of hard cornering.
My settings are as follows for a DD/track car:
Front
Caster = Max
Toe = 0
Camber = -1
Rear
Toe = .38 (degrees)
Camber = -2
I find this is a good streetable setting that gives some added performance on the track. FYI, my car has stock suspesion.
