please help w/offset
Old Mar 9, 2002 | 12:26 PM
S2K Power's Avatar
Default please help w/offset
im getting racinghart c2 3 peice rims and need advise on offset.
17x7.5 front w/ 225 45 r17
17x8.5 rear w/ 255 40 r17
whats the lowest offset i can get without rubbing or cutting or rolling fenders? I dont plan to lower the car for now but might in the future. thanks
Old Mar 9, 2002 | 01:21 PM
Kwando's Avatar
Check the FAQ.
If you can't find it I will help you out.
Click Here.
Old Mar 9, 2002 | 02:14 PM
S2K Power's Avatar
so on a 17x7.5 it should be +52 and 17x8.5 it should be +59 no less? If i go less in the rear will i have problems?
Old Mar 9, 2002 | 02:35 PM
Russ's Avatar
http://www.tolan-hoechst.com/cars/tirecalc.htm
Old Mar 9, 2002 | 08:00 PM
RT's Avatar
RT
You should be able to get away w/ +56 on the rear since the 255's are going to get pinched down a little on the 8.5" wheel.
Old Mar 10, 2002 | 07:52 AM
S2000_rider's Avatar
[QUOTE]Originally posted by S2K Power
[B]im getting racinghart c2 3 peice rims and need advise on offset.
Old Mar 10, 2002 | 08:19 PM
socal28's Avatar
The highest offset RH makes is +50.
Good Luck!
Old Mar 11, 2002 | 03:21 PM
S2K Power's Avatar
Good Luck!
The rim im getting is racinghart, not RH. Racingharts that im getting is a 3 peice rim so the offset can be custom. Two different companies racingharts are imported from japan and RH is made here in the US and not 3 peice. just thought i'd clear that up.
Old Mar 13, 2002 | 04:31 PM
00SType's Avatar
Hi S2K Power...
May I ask where you're getting these Racing Harts from? I spoke with Exact Motorsports in Milpitas about 17" C2s, but Racing Hart informed them that they do not have any 17" rims for the S2000 (offsets are too high). This was about 1.5months ago, so I was just wondering if something new has come up.
Thanks in advance.
Old Mar 14, 2002 | 07:37 AM
wlfsmith's Avatar
[QUOTE]Originally posted by 00SType
[B]Hi S2K Power...
s2kZac
Sep 25, 2009 10:44 AM
LS Boy
Jul 28, 2006 01:22 AM
JC_s2k
Nov 5, 2004 09:34 PM
lucki_dollar
Aug 17, 2004 07:05 AM
AusS2000
Jan 22, 2001 06:46 PM
