Pressed in studs on a spacer
Old Dec 14, 2010 | 09:28 AM
watch0bak's Avatar
Default Pressed in studs on a spacer
Can someone explain to me what pressed in studs do? Thanks!
- Sung
Old Dec 14, 2010 | 10:07 AM
irv_usc's Avatar
if the spacer is too wide you have two choices.
1. change to extended wheel studs
2. spacers 20mm + usually have pressed in studs so you can mount the spacer to your stock studs, then mount the wheel to the spacer's studs.
otherwise you won't have enough thread sticking past the spacer to bolt your wheel up.
maranelloboy05
Jun 19, 2013 10:52 AM
chispy9
Aug 29, 2012 03:24 PM
AFs2k
Sep 24, 2010 09:31 PM
thewhiteknight
Apr 8, 2009 05:38 AM
