which profile should i get
well, i have ADVAN RG-2 wheels on my car. 17" width of front is 7.5" while rear width is 8.5"
i want to change my setup when i buy new tires from 225/45 fronts and 255/40 rears.(current setup)
to 235mm front tires and 255 rears.
should i get 235/45 or 235/40?
my car is lowered 1.5 inches and i want to change the setup to reduce understeer.
i know that the tire profile is a % of the tire width, so if i keep the profile at 45 while increase the tire width im going to end up with a higher profile. but im afraid that if i reduce the profile number to 40 the profile will get much lower.
thank you
thank you
thank you for the input. i think ill go for 235/40/17 coz i dont want the tire to rub with the fender too. but in this case the rear tires diameter will be a little bigger than the fronts since the rear tires are 255/40.
i have another idea! will it fit well if i put 245/40/17 for my 7.5"front wheels? this size will have closer diameter to stock and ill eliminate the understeer.
235/45 and 255/40 should be more or less the same sidewall thickness/tire diameter. If you do 235/40 and 255/40 your rear tires will be much "taller" (overall diameter will be larger due to a much taller sidewall) and you'll get a bit of rake as a result. It looks rather aggressive but can be overdone and as a result look silly.
Personally, I'd go with 235/45 and 255/40.
Ah crap sorry I didn't do the math this time, I made a poor assumption that the 235/45 and 255/40 would be more or less the same overall diameter.
After actually doing the math, I would run 235/40 and 255/40 for sure.
