Question for Jim @ Tirerack
hi Jim, I just purchased a set of enkei rpf1s from tirerack and the front hubcentric adaptors don't fit the stock hubs. they're too small. the fronts are 17x8 45mm offset. do you have another size adaptor, can i run without them? thanks.
They probably sent out 4 rings of the same size (rear). That's what happened to me, just let them know and they will probably send you 2 for the front free of charge. In the meantime, you can run without them and it won't cause a problem.
