Quick Question
Old Feb 16, 2005 | 06:37 PM
babyslapmafro's Avatar
Default Quick Question
Will speedometer readings be more or less than actual speed when the car's wheels are replaced by smaller ones? and why.
-thanks ahead of time, mike.
Old Feb 16, 2005 | 10:01 PM
Warren J. Dew's Avatar
If both the wheels and tires are smaller, the speedometer reading will be higher. This is because the speedometer measures rotations rather than actual distance, and a smaller wheel/tire rotates more times per mile.
If you go to a smaller wheel but use a higher profile tire to make up for it - for example, going between the S2000 '00 16 inch wheel with '00 stock tires and the '04 17 inch wheel with '04 stock tires - the speedometer reading will not be affected.
Old Feb 17, 2005 | 11:36 AM
Jim@tirerack's Avatar
Former Sponsor
Warren is correct. As long as the tire diameter is the same height you will be fine.
If I can help let me know.
Curated Content Editor
Jul 14, 2017 10:51 AM
camuman
Jul 15, 2013 03:50 PM
secretdonkey
Sep 7, 2005 03:58 PM
CrazyPhuD
Feb 12, 2004 06:23 AM
Mark_12345
Dec 6, 2001 01:22 PM
