quick rim question
Old Jun 30, 2005 | 12:00 PM
ebeldesign's Avatar
Default quick rim question
I am planning on replacing my stock '01 wheels with 17X8 in the front and 17X8.5 in the rear. Both rims have +50 offset. When I went to an offset calculator, it told me that my fronts will be moved out by 24mm and the rears by 28mm.
My car is not lowered, will I need to roll the fenders, or will this just move the wheels out to the edge of the body. I am also concerned how much more the tires will extend out.
Any advice will be greatly appreciated.
Old Jun 30, 2005 | 01:12 PM
l8brakr's Avatar
You should be ok with stock height. If you lower you'll have to stay conservative with tire widths.
Old Jun 30, 2005 | 01:14 PM
03_AP1's Avatar
i wouldn't be too concerned, especially at stock height.
Old Jun 30, 2005 | 01:15 PM
l8brakr's Avatar
and be aggresive with camber
Old Jun 30, 2005 | 01:31 PM
s2ka's Avatar
Those aren't ideal offsets for the car, but if you don't lower it you probably won't rub. The tires are going to stick out a little from the fenders, not a great look.
Old Jun 30, 2005 | 01:40 PM
Jim@tirerack's Avatar
Former Sponsor
The 17X8.5 50mm offset will be very aggressive and will need a fender lip roll. The front with the 225/40R18 would be tight but should work.
Old Jun 30, 2005 | 01:57 PM
ebeldesign's Avatar
thanks for all of your help. Will the tires/wheels be sticking outside of the fenders?
or will it just pull them closer to flush with the opening?
Richie2.0
Feb 2, 2010 07:09 AM
chiney_dolly
Apr 20, 2009 12:21 PM
iljw
Nov 16, 2007 11:55 AM
McMuffin
Sep 9, 2007 06:29 AM
BB_S2K
Feb 10, 2007 07:44 PM
