Re-01
Old Mar 17, 2009 | 10:44 AM
Stealth_SUX_'s Avatar
Default Re-01
Hey as ive purchases a lot of the close out tires.
Has anyone put the re-01 225 16 on the front rim of an ap1... Ussually they say 205 front and 225 rear for ap1 but would the 225 fit in the front so you run 225 all the way around..
Old Mar 17, 2009 | 10:52 AM
User 121020's Avatar
I haven't done the non-stagger with the RE01Rs, but I will for my next street tire setup. I'm currently running 225/50/R16 Dunlop Direzza Z1 Star Specs on all four wheels and they seem to fit just fine. There is a more pinch on the front, but that's what's going to happen with the narrower wheel.
I am running a Saner FSB on full stiff, which initially caused a lot of understeer but does a good job of keeping the inside rear tire planted during turns. So for my setup, the 225s in the front made the car more neutral and definitely reduced the understeer. If you're running stock suspension, you will be more prone to oversteer if you choose to go this route.
Old Mar 17, 2009 | 10:54 AM
Im running stock just with espilar springs.. so i will get more oversteer...
cause right now with 205 re01 front and 225 in rear and i get a ton of understeer..
Old Mar 17, 2009 | 11:02 AM
What alignment settings are you running?
Old Mar 17, 2009 | 11:04 AM
about 2.5 negative rear and only about 1 negative upfront cause the idiot who did it couldn't get to -1.5 for some reason
Old Mar 17, 2009 | 12:37 PM
Yeah, that sounds odd. My subframe is shifted and I have -1.3 on the driver side and -2.3 on the passenger side. I would also check to make sure your caster is maxed out. Changing the rear toe will also affect your tendency to over/understeer. General rule of thumb - toe in increases understeer, neutral to toe out will increase oversteer. With that said, I'd set your rear toe to between 1/4" to 3/16" total toe in and get the front end sorted out.
If you change your alignment, I think you'll get the handling characteristics you want.
Old Mar 17, 2009 | 12:59 PM
front end is in perfect condition, thats why i was like wtf.. caster was maxed out like 7 degrees or something. i dont remember.. Everything was in spec, expect couldn't get the negative camber up front.. dont know why he couldn't
Old Mar 17, 2009 | 01:02 PM
but back on topic, since i have a ton 225 re01's, i want to run them up front too.. so from reading i guess i can but i may have some oversteer.. right.....
Old Mar 17, 2009 | 02:21 PM
s2kAtTracks's Avatar
in the rear i'd go 245/45/16(closer to stock size) even though the stock tire was stamped 225/50/16.
Old Mar 17, 2009 | 02:46 PM
The 225/50/R16 auto-x street tire offerings (RE11s, Z1 * Specs, XS, RE01Rs, etc.) are better than what is available in the 245/45/R16 size. The 245/45/R16 Hankook Z212 is just about the only one you'd want to run, if looking for high performance and it probably won't be as good as the other brands in the 225 size. Actually, the 225 RE01R is nearly as wide as some of the 245 RE01Rs. Here's a pic that shows the stacked height of a few different tires -
Starting from left rear, going clockwise - 245/45/R18 Dunlop SP600s, 245/45/R18 RE01Rs, 225/50/R16s RE01Rs, and 225/50/R16 Hankook Z214 C70s. Only the Z214s are mounted. The RE01R in the 225 AP1 size is the same height at the 245 SP600 and only 1ish inch shorter than the 245 RE01Rs. The 225/50/R16 Z214s are much shorter.
OP, you'll be fine with 225 in the front - especially if your car understeers, right now.
King Mire
Mar 3, 2011 08:56 AM
Forcednduckshn
Jul 26, 2008 03:14 PM
Boost76
Nov 26, 2007 08:58 AM
Davidss
Jan 26, 2007 02:38 PM
BSeriouS
Feb 20, 2006 09:49 PM
