rim size question?
Would a 18x8 with a 44 offset all around work on a AP2? What is the ideal offsett and width for a 18's???
We have a wheel/tire forum. This is nowhere near a topic for Technical.
Would a 18x8 with a 44 offset all around work on a AP2? What is the ideal offsett and width for a 18's??? OEM 17" rims are 7.5" wide in front with about 55mm offset. 8.5" wide in rear with about 65mm offset. |
Moving to Wheel/Tire forum
If you are going to run the same wheel all the way around I think 18X8 and 44mm offset will be a problem. You would need to stay on the narrow side of tires and probably roll the fender lips.
