ROJA FORMULA 5
Ok i finally got my rims in the backs are 18x9 with a +65 offset...they still seem to stick out at stock height. two people have told me my alignment is off and that they will "tuck once we dropped the car. I have my buddyclubs on order so its jst a matter of time..this is the correct offset correct?
If you are having problems.....?? What size tires are you running....??
Just because the wheel & the offsets are correct.........you can still cause / create a problem by running to wide a tire:
255 - Will fit........No problems / No Rubbing
265 - Should fit fine.......most likely no problems.
275 - Not sure....?? - Might require some camber tweakin.
