Rolled arches,and still rubbing under acceleration?
Old Dec 10, 2011 | 02:16 AM
Zebafxxkindee s2k's Avatar
Originally Posted by afzan
Originally Posted by Zebafxxkindee s2k' timestamp='1323472108' post='21225130
causing issues under high acceleration you can feel it vibrating
it's probably your cv buckets, get driveshaft spacers or flip the buckets left/right
there are tons of threads on s2ki about this common problem
Would this cause it to rub on the tyre? It's only since I've lowered it I have had the problem. Seb
Old Dec 10, 2011 | 05:32 AM
DFWs2k's Avatar
No, that wouldn't cause it to rub, but sometimes that does happen after changing your ride height.
Do you hear rubbing? Or just the vibration?
Sent using free Tapatalk - Android FTW
Old Dec 10, 2011 | 06:00 AM
afzan's Avatar
a 8" wide wheel and 225 in the rear isn't very aggressive, do you know what your alignment specs are? (more specifically rear camber).
Are you sure you're rubbing? It's hard to tell from the pics but the tread wear looks normal to me, which would point to it being the CV buckets - here's a thread with info: https://www.s2ki.com/s2000/topic/693...ration+lowered
Old Dec 10, 2011 | 08:57 AM
Hi guys as pictured there is a mark around the edge of the tyre.more on the passenger side than drivers side tho I'm sure that this is what I can feel under acceleration I'm putting it down to the tyre being to big at the moment as it is quite high walled for a 40 .I also don't see why when I've dropped the front 30mm and rear the same the front sits higher?
Old Dec 10, 2011 | 09:54 AM
ryuken's Avatar
Maybe you can have a friend stand outside and observe the car as it accelerates?
Old Dec 12, 2011 | 02:16 PM
Update I had fitted the front springs on the rear and the fronts on the back noticed after a phone call to the company who supplied them.How embarrassing school boy error never the less it's fixed and sits nice and level now !
Old Dec 12, 2011 | 04:35 PM
DFWs2k's Avatar
cool, next time supply some not whacky angle pictures, and we may be able to catch that
Old Dec 12, 2011 | 05:54 PM
clarkster009's Avatar
Originally Posted by Carbon Blue
Originally Posted by AZS2KDancer' timestamp='1323479248' post='21225348
Have you ever used a period or other punctuation?
have you ever considered that english may be a second language to him?? Give him a break What offset are your wheels? Im guessing that your axle cups are pitted and need to be swapped from left to right.
Well he is from ENGLAND, so your logic doesn't work Therefore, it's most likely due to lack of intelligence. But yeah, try swapping the buckets or getting new axles.
S2Tae
Nov 2, 2010 06:47 AM
STAIN
18
Feb 19, 2008 09:00 PM
STAIN
Feb 14, 2008 11:28 AM
SSSS2222KKKK
May 12, 2003 11:55 AM
ukliam
Oct 30, 2001 01:54 PM
