Rota wheels
Maybe I missed it but I have been researching this all week... I understand the bore on the front hub is larger than the rear - but I also know that hubcentric rings ARE needed. I have had rota wheels on my miata and my civic si prior to the s2000, and those both had hubcentric rings so that the wheels would mount centered onto the hub correctly. What size do we need (outer and inner od)? And for you guys running the grids, did you just buy four 17"x9" wheels & have the fronts bored to fit the front hub or did they fit just fine w/ hubcentric rings? Lastly should I be concerned about my VSA going ballistic if I have four tires all the same size? From what I have understood it shouldnt be but I just want to get everything straight before I start forking money over for anything. I also assume I can just swap over the tpms from the 08 stock wheels to the rotas. Lastly, my car is bone stock as of now - will 255/40/17s look right up front? I honestly like the idea of rotating my tires if I have them all the same size.
Your Suzuka is hot by the way
Go to 949 racing they have rings for the 6ulr wheels which are 73.1. I used the exact rings with My Rotas. They have front and rear get two of each. They are aluminum not plastic so they will last, and 3 or 4 dollars a piece. You cant beat that.
In fact heres the link
Hub Rings
Hub Rings
.And thanks
is this the +42 set up on a stock suspension?
ive been looking at some rotas but dont really want to mess with the suspension or have to roll the fenders...
are those 17s?
Originally Posted by jordannn93' timestamp='1313788782' post='20895511
I will have to get some better pictures when the sun is out. It's been raining here in PA on and off.
are those 17s?
