RPF1 Over BBK
Old Nov 28, 2011 | 04:00 PM
learnerspermit's Avatar
Default RPF1 Over BBK
Looking for a cheap extra set of track wheels. I was curious if a 17X9 +35 will clear my BBK.. I tried a friends 17x9 +45 and it would not fit.
Any input?
Thanks
Old Nov 29, 2011 | 12:04 AM
dc2-2-ap1's Avatar
Check out the brake section. What bbk are you running? The 17x9 rpf1 will not fit any bbk to my knowledge. The 17x8 does fit with spoon and stoptech.
Old Nov 29, 2011 | 06:06 AM
deepbluejh's Avatar
Why would a 17x8 fit and a 17x9 not fit? It would seem like a 17x9 +35 would give you plenty of space for a BBK.
Old Nov 29, 2011 | 06:14 AM
04S2kSS's Avatar
I havent seen anyone(To my knowledge) with 17x9 with BBK...Reason is that the 17x8 is a non concave RPF1. The spokes poke rather than concave giving clearance for the bbk to fit. The 17x9 is flat and closer to the hub and the BBK would rub. You may be able to pull it off with a spacer...
Dre
Old Nov 29, 2011 | 07:28 AM
Thanks guys
I figured as much, Im running an AP brake setup and was just wanting some cheap nice quality track day wheels without buying more Volks. And I have always liked the RPF1 I have some loose spacers and will see if I can stack enough on my friends +45 and then subtract the difference I added and let you know what fits and see if its available.
Old Nov 29, 2011 | 08:27 AM
clarkster009's Avatar
FYI you could try going with the Enkei PF01 wheel. The 17x9 +48 is supposed to clear the AP Racing and Wilwood kit (as told to me by a member on the Racing and Comp forums), and they also make a 17x9 +35 which almost surely would fit. The member is the white AP2 with the ASM or Shine fronts...he used to have silver PF01s and then switched to black RPF1s. He doesn't have a BBK but said friends that did test fit the wheel. Don't recall the user name.
Old Nov 29, 2011 | 08:30 AM
afzan's Avatar
17x9 +45 RPF1's are very close to the stock calipers as it is
Old Nov 29, 2011 | 09:02 AM
chuhsi's Avatar
Wow, I wouldn't have guessed that an RFP1 17x9 45 would have so little clearance. I have a 17x9 57motorsports wheel and I have maybe a 3/4" gap between the wheel and my bbk caliper.
stoptech and ap racing both have print-outs so you can try to fit with your wheel
albertg
Jan 11, 2013 11:35 AM
TerminatioN
Jul 3, 2012 10:19 AM
c32b
May 8, 2011 12:41 PM
Torqueless
Nov 29, 2008 12:06 PM
Steven2k
Apr 9, 2007 09:33 AM
