hi, to all seniors here, just wanna share about this setupp on my car, the car will be lower till one finger gaps between tire and fenders, however im wondering can i have this fit? setup for this i might choose 225/40 R 18 and 255/35 R 18 for rear..
any suggestion?
what offset should be able to fit, i like a lil bit of aggresive offsert but not too much, just a lil...
should i run on extra camber?
thanks,
best regards,
Steve.
This post contains some information, but actually is missing some very important nuggets. For example, what are the dimensions and specs of the wheels you are running? The specs there will determine how what size tires might be best for you to run.
Questions to be answered by you:
Dimensions of wheels?
Specs/offsets of wheels?
Fenders rolled?
Type of tire?
hi , yeah i wanna run on 18 with 8,5 and 9,5 , also 225/40 and 255/35 tire, then im now struggling about the offset for this one, so i need advice for the offset of this specs... fender rolled for the rear... tire will be toyo proxes t1R
they are very flush and just BARELY rub in the front. with a tad more camber they wouldn't rub at all. i'm aligned to oem spec. they are 18x8 and 18x9 too fyi. i was wrong earlier
