S2000 Offset Guide for Flush fitment Widebody included
Old Jun 17, 2011 | 08:18 PM
TheChazz's Avatar
Default S2000 Offset Guide for Flush fitment Widebody included
Well guys in my venture for the perfect fitment, I have made a sheet to calculate fitment.
PLEASE NOTE: This is for Flush fitments. (The outside of the wheel meeting even with the sides of the car, specifically at the top of the wheel arches. You will need a stretched tire or a slightly higher offset (+5-6mm) than listed if you are lowered and need to tuck.
Also, these measurements are based on the "UK Spec" Camber adjustments of -2* Front and -2.5* Rear.
As all wheels and tires differ slightly, it may be a safe bet to aim for slightly higher offset regardless (+5-6mm) to ensure clearance, then use spacers as required for the PERFECT fit.
You can see calculations for a stock S2k on my site or download the Sheet to input your own custom flares.
http://thechazz.com/?p=4567
or download the spreadsheet directly here: http://thechazz.com/wp-content/uploa...06/offsets.ods
Use Excel or OpenOffice.org to open the file.
If anyone here can convert the sheet to a web form, Ill be happy to host it.
Old Jun 19, 2011 | 07:25 PM
Mr. Francesco's Avatar
Interesting. I'll have to play around with this later.
Old Jun 19, 2011 | 08:37 PM
TheChazz's Avatar
Sure thing
It should be pretty accurate. Figured at -2*F and -2.5*R camber also.
Old Jun 20, 2011 | 06:58 PM
petawabit's Avatar
obviously, flush means different things to different people. are these calculating appropriately-sized tires to match the rim diameters?
Old Jun 22, 2011 | 04:01 PM
TheChazz's Avatar
By Flush I mean The face of the wheel is flush with the side of the car. Ill add a note to the OP to define.
You could still use an appropriate width tire on a flush fit wheel for a non-slammed car. As long as the fenders are rolled, the natural camber process that occurs when the suspension is compressed should clear the tire. However, I do recomend a slightly higher offset to be sure, you can always use a thin spacer to bump it back out if you have room.
Old Jun 26, 2011 | 11:37 PM
petawabit's Avatar
yeah, i'm trying to find an optimal setup in the 17" rim category, but hard to find 10 or 11" one-piece rims Might have to get ccw's.
Fear88
Apr 13, 2013 04:37 AM
TheChazz
Jun 17, 2011 08:16 PM
TheChazz
Jun 17, 2011 08:12 PM
amongmany
Oct 23, 2003 10:16 AM
samlee888.com
Sep 4, 2002 03:43 AM
