S2k Wheel setup
Agree with B Serious. There's a 17x9 + 45 and a 17x9.5 +38 as far as I can tell. For both, you will need to roll fenders and relocate the rear tab. You'll need camber adders, preferably with an upper arm or joint for the fronts. If you do not want to touch your fenders, you need to get rid of these wheels. Should learn the lesson to not buy wheels first and figure it out later. When you're going wider wheels, you need to figure out what the car can handle.
There are a few wheels in 17x9 +60-63 that you can run without modifying your fenders as long as you use a front camber adder. I ran 17x9 +63 with 255/45/17 tires on stock fenders for years but I was lowered and had camber.
dragonash
May 4, 2015 04:19 PM
