Is sandblasting required for powdercoating?
Old Jan 13, 2006 | 10:49 AM
Iceman1's Avatar
Default Is sandblasting required for powdercoating?
i want to powdercoat my stock AP1 wheels black. is sandblasting required? what all is involved in powdercoating?
thanks.
Old Jan 13, 2006 | 12:40 PM
xviper's Avatar
To ensure proper paint adhesion, the part needs to be completely bare to the metal. To be certain of this, yes, sandblasting is the best way.
In power coating (and you can do a Google search to see this), a charge is put into the part with an electrical current. While charged, dry powder paint is sprayed onto the part. Since the part is charged, the paint adheres to the metal in a clean, uniform manner. The whole thing is then put into an oven to bake the paint on.
Old Jan 13, 2006 | 07:18 PM
boyguan's Avatar
i was looking to powdercoat my wheels as well
i called around and best so far is 75 per wheel which includes stripping and a clear coat
Old Jan 17, 2006 | 07:57 AM
Iceman1's Avatar
[QUOTE=xviper,Jan 13 2006, 04:40 PM] To ensure proper paint adhesion, the part needs to be completely bare to the metal.
Old Jan 17, 2006 | 08:27 AM
xviper's Avatar
Originally Posted by Iceman1,Jan 17 2006, 10:57 AM
thanks for the process... i guess what i need to know is if the part (wheels) is NOT sandblasted/stripped before it's powdercoated... what are the advserse effects?
will it still be better than painting?
will it start to chip soon?
I suppose you could try. I find with such things, that if you put in just a little effort, the results will end up being disappointing. If you prep the rims really well and spray painted them, they'll probably last OK for a couple of years. After that, they will likely begin to chip and peel.
Old Jan 17, 2006 | 08:46 AM
Iceman1's Avatar
wait... are you describing this for "spray painting' or for "powdercoating WITHOUT sandblasting" ? i got confused
Old Jan 17, 2006 | 11:57 AM
xviper's Avatar
[QUOTE=Iceman1,Jan 17 2006, 11:46 AM] wait... are you describing this for "spray painting' or for "powdercoating WITHOUT sandblasting" ? i got confused
Old Jan 17, 2006 | 12:09 PM
Ubetit's Avatar
Your rims probably won't be sandblasted. Most likely they'll be bead blasted using plastic beads (maybe glass depending on the finish and metal you are trying to strip). Plastic beads will strip paint without damaging any of the surface metal.
Do NOT skimp on that process. As they say in the detailing business, the results are all in the prep work. As xviper says, most shops won't guarantee the finish until they can strip it to the bare metal.
Old Jan 17, 2006 | 01:15 PM
xviper's Avatar
Some processes will use walnut shells.
Old Jan 17, 2006 | 01:50 PM
Iceman1's Avatar
Originally Posted by xviper,Jan 17 2006, 03:57 PM
I kinda doubt any powder coating shop will do the job unless the part is properly sandblasted. At least they won't guarantee the work.
You could try to just sand it really well and see what the shop says.
BTW, most powder coating shops will do the sandblasting for you.
thanks fellas... my powdercoating shop gave me 2 prices... 1 with sandblasting and a lower price without sandblasting... what im trying to figure out is...
if i choose the NON-sandblasted route... will that still be better than regular "wet" painting?
im NOT going for showroom quality... only need it to last 2-3 years... but will see time on hot road-course enviornments...
