serious wheel issue
Hi guys i think i have a prob here...
well i got meself a set of RPF1 17x9 +45 rims and installed a set of ADVAN A050 on it with 255/40 and when i put on the wheels while my car is on a hoist and it looked like my car had 4wd wheels on or something...
well i did read some others post the same issue but my prob is i had semi's and the tyre seems to be a bit more wider than normal street tyre so i'm not sure after i lower my car and put -3 camber on it would the wheels stay inside the fender or still it would stick out?
i had roll fenders already as i know it gonna rub like hell...just wanna know how can i keep those wheels inside those fender's...?
do i need to pull out the fender as well to keep them inside?
thxs guys
thxs guys
hi guys me again..
finally got my car lowed and around 1.5 finger from fender..and my mech took my car to a well known wheel alignment work shop and came back with a camber of -3 front and -2 rear...and as soon as as hear this i am kinda worried...wether this is the right set up or not cos i read lots of post and about 99.9% of ppl use a bigger camber down the back..so my question is the alignment is right set up or not...????
as i will be bringing the car to track ...
and i'm using spoon full spec damper current model..and ADVAN A050 tyre
More front camber than rear is actually the norm for optimized rwd track cars. From the factory, cars usually have more rear camber than front to be on the understeery side.
That said, the factory '00 suspension's roll stiffness is a little biased to the rear, so you might consider running a stiffer front bar...
