Small problem...Volks.
Originally Posted by Ubetit,Mar 26 2006, 10:29 AM
I have a thin walled deep socket with an outer plastic protector that can be removed to make it even thinner. It works on evreything. Get a telescoping lug wrench to use with it.
Where did you get that,???
Originally Posted by kayvan_pour,Mar 26 2006, 08:10 AM
Here are some pics of my wheels and the lug nuts I'm using, sorry the pics are crappy. Is this the proper set up??? Or should I buy those mugen lug nuts like I posted above?
oem=conical (rounded)
aftermarket= tapered (60* taper)
to make it fit in hole.. buy a thin sidewall socket 19mm and a torque wrench and keep in car all the time. never use oem. thats made if u have a flat. and dont care about proper torque. or buy a 19mm (male end) to 19mm (female end) w/ a thinner sidewall on the socket..
this way u can use oem.. pop a diff end on it and still work fine.
personally i have a craftsman top of the line torque wrench in my trunk 24.7 w/ socket
So if we purchaed a set of Volk's we need to get lugs as well? Sheesh.
I just thought buy rims, take to tire store...mount. Is there anything else I should know as I'm close on pulling the trigger?
Oh, you'll need the centering rings. And do you want the center caps. They're not included unless you ordered them.
I have the rays lug nuts and I can use the stock wrench on them with no clearance issues.
I also tried the generic chrome lug nuts that came with the volk wheels and those worked fine too, but I wanted the bling and extra weight savings of the "duraluminium"
just what u gotta pay to have the right equipment.
imo worth every penny. i like the attention to detail of 3000$+++ wheels and their corresponding nuts/hub rings etc (all the rays wheels ive bought, ive also thrown out the extra $ for the anodized aluminum hub rings rather than simple plastic ones.
caps are an optional extra
