spacer size
Old Nov 14, 2006 | 08:20 AM
ohms2k's Avatar
Default spacer size
just needed an adivce/help...
I am droppin my car 1.5 inches this winter on the OEM rims and wanted to know which spacer size (mm) to use so I would not have any rubbing problems and to have that wide look
the sizes i found were 5mm,15mm, and 20 mm
would it be a problem to use diff size spacers for the fronts and the rears?
thank you
Old Nov 14, 2006 | 08:41 AM
minh's Avatar
a spacer would more likely to make the rims rub as it will decrease your offset
Old Nov 14, 2006 | 08:55 AM
ohms2k's Avatar
i understand that it will decrease the offset...thats what i want...but the question is which size (mm) should i use to not rub...maybe somebody that has spacers can answer my question
Old Nov 14, 2006 | 10:14 AM
minh's Avatar
front
6.5
JoeyBalls
Mar 8, 2010 11:13 AM
Wicked04
Apr 13, 2007 02:07 PM
DDuds2k
Feb 21, 2006 03:25 AM
vtecvoodoo
May 19, 2005 09:20 PM
s2000alex
Sep 10, 2004 12:38 PM
