Spacer w/ CE28n
Old Apr 3, 2008 | 08:25 AM
regmilla's Avatar
Default Spacer w/ CE28n
I am looking to run a spacer with my CE28ns but I don't know if I should go with the 10mm or 15mm spacer. I was running work meister s1s that were 18x9.5 +63 with 265/35/18s. Now I am running CE28ns 17x9.0 +63 with 255 40/17s.
What is the highest I can go with out rubbing on the rear fender?
Thanks!
Old Apr 3, 2008 | 08:43 AM
IIGQ4U's Avatar
It would help to know if your fenders are rolled.
Old Apr 3, 2008 | 09:16 AM
Jim@tirerack's Avatar
Former Sponsor
I would not go more than a 10mm spacer.
Old Apr 3, 2008 | 09:19 AM
IIGQ4U's Avatar
17x9+63 offset with a 255 rear tire and 15mm spacer is easy so long as his fenders are rolled. I would recommend the Kics spacer because they lock down your original wheel studs and are very well made.
Old Apr 3, 2008 | 12:15 PM
regmilla's Avatar
My fenders are not rolled at the moment. I don't really want to roll them so I guess I will go with the 10mm. Thanks!
Old Apr 3, 2008 | 12:16 PM
AP2's Avatar
AP2
Old Apr 3, 2008 | 12:22 PM
nevaland9's Avatar
with some rolling and light bumper cutting we get 17x9.5+38 all around super duper slammed too.
Old Apr 3, 2008 | 12:39 PM
regmilla's Avatar
Pics?
Old Apr 3, 2008 | 01:42 PM
jimbrowski00's Avatar
You gotta take your wheel off to check if it has clearance for the studs.
The og studs are about an inch so if you run a 10mm spacer your wheel needs to be able to clear another 16mm.
Just a heads up!
jim
Old Apr 3, 2008 | 01:45 PM
regmilla's Avatar
Thanks, I got extended studs also.
