spare tire size
Old Jan 20, 2006 | 09:37 AM
blurnj13's Avatar
Default spare tire size
Hi,
I tried searching, but no luck. After 2 years of driving around, just recently found out I didn't have a spare tire. I bought one from a forum member, but was just curious if it was the right size. The wheel size was 16, which sounded right, but when I put it up against the other tires, the diameter seems much smaller. I would mention the exact size of the spare I have, but unable to since I am currently at my desk at work. I just wanted confirmation that the diameter of the spare should be smaller than the full sized wheels+tires. Thanks.
Old Jan 20, 2006 | 01:20 PM
xviper's Avatar
It is much smaller diameter than the service tires/rims. This is why you must never use the spare on the rear. Read you owner's manual on what to do when you have a rear flat.
Old Jan 23, 2006 | 06:47 AM
blurnj13's Avatar
Thanks. yeah I already read other posts regarding the "never put the spare on the rear if you love your diff". I was just curious whether I had the correct spare tire for the s2000, since it seemed way smaller than I would have expected.
-Anthony
Old Jan 23, 2006 | 08:17 AM
xviper's Avatar
Well, it is called a "compact spare". Just make sure the bolt pattern is meant for the car in case they gave you one from another kind of car.
Old Jan 23, 2006 | 11:33 AM
blurnj13's Avatar
Yeah the bolt pattern looks right. Thanks again. I'm just hoping I never have to use it. Hopefully I won't get something a can of fix-a-flat won't temp fix.
NoRawkus305
Jan 18, 2007 12:07 PM
chalupa
Aug 3, 2006 12:53 PM
nolas2k
May 13, 2001 11:02 AM
