Speedomter question
hello all
I have a quick question for everyone. (I tried doing a search allready, and couldn't find an answer)
If i were to get different size tire on my S would that effect the speedomter and if so how can i correct it.
I am 90% sure if would effect the speedometer, but i just want to know for sure, and how the rest of you corrected it.
thanks
Xv7vX
thanks
Xv7vX
Your speedo will be affected only if the overall wheel/tire diameter will be significantly different from the stock setup. If you have a smaller diameter, the speedo will read fast. If you have a larger diameter, the speedo will read slow. You can correct it with this:
http://www.blackrobotics.com/
I have this to correct for my different rear end gears.
