Staggered offset, Squared tires.
Old May 15, 2015 | 07:34 PM
LenS2K's Avatar
Default Staggered offset, Squared tires.
Hey guys,
I wanted to know your opinion on having a staggered offset with a squared tire set up for the track. Reason I'm asking is I have stock front fenders with asm overfenders and I was thinking of doing 17x9 +45F and +22R with a 255/40 tire. Would offsets make a difference in handling as is I were to do a full +45 all around? Thanks...
Old May 15, 2015 | 11:56 PM
s2000Junky's Avatar
Yep, the car will feel more stable at speed with the increase in rear track width from the lower offset, but you will effectively be lengthening the leverage point/axis on the rear suspension, effectively reducing the spring tension effectiveness, softening it up. The net result overall with the softer rate as well as the wider track width, will be an increase in lateral traction on the rear. A retune of the suspension may be warranted if your a track/performance junky and trying to maintain your current handling balance. If you felt the rear needed to hook up better, then you may find its a step in the right direction without any rebalancing, especially considering a non stag tire set up. Generally stock for stock, this would be an improvement for the ap1 and a toss up on the ap2. Driver preference still influences the wheel/rubber/suspension set up.
Old May 16, 2015 | 12:22 AM
LenS2K's Avatar
I kind of understand what you're saying? But could you put that in beginner drivers language? lol
Old May 16, 2015 | 12:32 AM
s2000Junky's Avatar
No, sorry lol
ayrton22
Oct 5, 2018 03:43 PM
rwheelz
Sep 22, 2009 01:16 PM
Goldygopher
Apr 3, 2008 04:57 PM
wazzurp
Dec 22, 2007 08:34 AM
Fubawu
Jan 2, 2007 05:56 AM
