Stock AP1
I know this topic has been beat to death but i cant find much searching the forums on tires for the AP1.
I thought i remember seeing the the S-02 was one of the best tires you could run on the 16s because of the way it sits, if i remember right the 225 sits like a 245. I was told that that tire was discontinued although I can still get it.
Does anyone know of an alternative that will either be equal or work better then the S-02 for pure dry summer performance. I have been looking around but not many summer tires are available in anything bigger then a 225.
Thanks in advance
Thanks in advance
There are more important things than the "amount of rubber on the road", but I'm sure that they'll both have a similar contact patch area to the S02 at similar inflation pressure. Both should give better dry grip.
Yeah i know there are many other things that are probably more important then the actual contact patch, but i was mostly just curious how the S02s compare to other tires, but i will probably get the RE01s since i was already looking at them.
