Storing Tires
Old Oct 6, 2006 | 05:47 PM
s2k_9000rpm's Avatar
Default Storing Tires
i purchased two sets of fronts and need to store the second pair until i run through the first, which will probably be quite some time from now. is there a proper way to ensure they survive until i'm ready to use them or should i try to sell them?
Old Oct 6, 2006 | 06:17 PM
ppipe's Avatar
It is generally accepted that modern tires have a maximum shelf life of approximately 5 years regardless of use. Should your storage plans exceed a significant portion of this shelf life, then I would suggest you sell the tires. If your storage plans are not longer than say 18 months the preferred storage is as follows:-
i) clean tires mounted on clean wheels:
ii) inflated about 5psi above normal running pressures(but never exceeding the
maximum pressure rating displayed on the sidewall);
iii)stacked horizontally in sealed bags and stored in an enviroment that does not
suffer any temperature extremes, nor humididty extremes;
iv) lastly do not store in an area that contains any running electric motors as
they produce ozone gas when running , and this is deadly to rubber items.
Old Oct 6, 2006 | 07:07 PM
Slows2k's Avatar
Moving to wheel/tire forum.
Old Oct 7, 2006 | 09:26 AM
Jim@tirerack's Avatar
Former Sponsor
ppipe is on the money. I just use big garbage bags. Just stcak them one ontop of the other and keep them out of the elements.
Old Oct 7, 2006 | 11:40 AM
do they need to be mounted on to a wheel? i don't have a spare set of 17's around
8_ball
Mar 2, 2010 03:30 PM
S2S
Dec 7, 2008 11:13 PM
hansel
Dec 2, 2004 03:56 AM
Silver S2000
Dec 18, 2002 11:13 PM
N94247
Mar 21, 2001 12:48 AM
