Straight to the point.
Old Jun 27, 2002 | 08:39 AM
kjs007's Avatar
Default Straight to the point.
I want to upgrade my wheels and tires to 18". What size tire, width and offset would you guys with 18" suggest? Do I have to do larger in the rear then in the front? Or can I go with the same size all around? Like 225/40/18? I did a search and I could not find any straight and simple answers.
Much appreciation
Old Jun 27, 2002 | 01:57 PM
Jim@tirerack's Avatar
Former Sponsor
There really is no straight and simple answer. You can run a number of different wheel and tire sizes in the 18" on the car. The offset is going to be around 48mm front and 55 to 65mm offset rear. The 225/40R18 front and 255 or 265/35R18 rear are all good choices.
If I can help let me know.
Thank you
Jim 800-428-8355-364
Old Jun 27, 2002 | 02:23 PM
kjs007's Avatar
Thanks, Jim. Good to hear from a fellow Hoosier. Can I do the same size front and rear and still be ok? I really don't want to go that big in the rear. I appreciate the help and will contact you when I find something out further.
Old Jun 28, 2002 | 05:36 AM
Former Sponsor
I suppose you can do the same size but I don't think it will have an advantage for handling on the car. As long as the tires arre the same height front and rear you are ok on the car. The 225/40R18 alll the way around will work on the car.
Thank you
Jim
Old Jun 29, 2002 | 08:32 PM
kjs007's Avatar
Jim, What is the bolt pattern? And the offsets you gave me in the earlier post is that stock?
Old Jul 1, 2002 | 04:58 AM
Former Sponsor
The bolt pattern is 5-114.3 and stock offset is 55 front and 65 rear.
Jim
Old Jul 1, 2002 | 04:45 PM
kjs007's Avatar
Jim, If I go with 225/40/18 all around what offset would you suggest?
Old Jul 2, 2002 | 07:02 AM
Former Sponsor
You would want to be around 18X8 and 48 to 50 mm offset should work on the car.
Let me know if I can help.
Jim
minboost
Sep 19, 2010 08:14 PM
apsingh78
Feb 22, 2009 07:05 AM
lazykiwi
Apr 7, 2006 07:00 PM
78roadrocket
Jul 15, 2004 07:30 PM
ytyper
Oct 3, 2002 07:31 PM
