are these too aggressive
Old Sep 1, 2007 | 09:49 AM
silentdancer's Avatar
https://www.s2ki.com/forums/index.php?showtopic=342793
Old Sep 1, 2007 | 10:34 AM
vspc2nr's Avatar
sorry but i still dont understand this "offset"
Old Sep 1, 2007 | 10:58 AM
2. What is this offset business?
The offset is the distance from the wheel centerline (midway between the front and back of the wheel) to the mounting face of the wheel that contacts the hub of the vehicle. The S2000 requires high positive offsets. A positive offsets indicates that the mounting surface of the wheel is closer to the front of the wheel than the back. This offset is expressed in millimeters, and is seen as numbers such as "+40" or "et40."
Since the offset is measured from the wheel centerline, and not the outside edge, the required wheel offset depends on the width of the wheel and tire.
Old Sep 1, 2007 | 11:00 AM
okay think of it like this, a low offset such as +12 will stick out further than a +40, the S uses high offsets, most people run 9+63 rear.
Old Sep 1, 2007 | 11:04 AM
AP1_S2k's Avatar
I have a 17"x8" rear set up with +42 offset and I am only lowered about an inch and I am running a custom alingment to not rub
Old Sep 1, 2007 | 11:38 AM
vspc2nr's Avatar
so what tire work with this set or is it even worth buying. I can roll the fenders if thats the case and if the 92 Toyota Supra's uses the same bolt patern
17 X 8, ET 36 and Rear 17 X 9, ET 33
and so the highter the # the less it sticks out??
Old Sep 1, 2007 | 12:21 PM
WashabiS2K's Avatar
17x9 +33? look into buying a new fender...
but to answer the thread topic: YES all the sizes specified are quite aggressive and would take some work to make it fit correctly without rubbing (unless you arent lowered)...
you could opt with these options to maybe have them fit...
1.) roll/flare the fenders
2.) relocate the bumper tabs
3.) lots of negative camber
4.) run super duper stretched tires
5.) do not slam it and drive it like a 4x4
Old Sep 1, 2007 | 02:01 PM
yes, i do not recommend that offset
GrantGPW
Apr 10, 2015 12:38 PM
street_ruler
Oct 16, 2007 12:51 PM
DeeQs2k
Jan 31, 2007 08:55 AM
CourageOO7
May 26, 2006 09:34 AM
Radorotrex
Aug 21, 2005 05:00 PM
