Tire Break In.
Old Sep 13, 2002 | 07:34 AM
Kekoa's Avatar
Default Tire Break In.
Well, I just got a set of CE28N's with Bridgestone s-03's. I was wondering if there is a break in period for new tires. I'm asking because I took a corner last night at around 25 mph. I gave it a little gas when coming out of the corner and the rear slid out. Luckily, there were not any car cars around and I was able to recover. Aren't S-03's supposed to be pretty sticky??
Old Sep 13, 2002 | 08:01 AM
Prolene's Avatar
There generally is a break in period. The 'oils' or chemicals on the surface having to do with manufacturing, molds, etc., might have to be worn off. Also, the beads might be quite as grippy on the rim for a bit. I bet your tires will have a lot more grip later than they do now; no worries.
I tend to gradually work up cornering and braking on new tires for a few days as I also get familiar with their tendencies.
Old Sep 19, 2002 | 07:11 AM
Jim@tirerack's Avatar
Former Sponsor
The break in period can be as long as 500 to 1,000 miles. The thing you have to remember with your OE tires is you were breaking in your car and your tires at the same time. As soon as the car was broke in the tires were as well. You don't need to do anything special to the tires other than driving on them.
Jim
Old Sep 19, 2002 | 08:14 AM
Kekoa's Avatar
Thanks guys. They are getting stickier by the day. Just like you said they would.
Old May 25, 2004 | 03:46 PM
Jasonoff's Avatar
Banned
Is it bad to do an autox on new tires? Say after 100 miles?
Is this just surface garbage that needs to burn off?
Old May 26, 2004 | 06:09 PM
wanabe's Avatar
with my s03s i can tell its gonna be about 500 miles...
they are getting better, but not there yet-
Old May 26, 2004 | 06:11 PM
Jasonoff's Avatar
Banned
you drive hard on them or just regular driving?
I don't want to overheat the rubber or something stupid. If i can just drive on them hard for a few hours and PRE break them in then ill do that.
Old May 27, 2004 | 12:36 PM
wanabe's Avatar
dont drive them hard until broken in...
prob is that they harder until broken in- easier to lose control (although some like that- easier to drift!!)
after they are broken in they will be stickier.
straight lines and normal corners are no prob.
btw, just had mine aligned... what a diff!!!
strong recommendation to do that after giving new tires and wheels some time to set to the car.
Old May 31, 2004 | 09:42 PM
dreamcation's Avatar
It took me about 2 weeks to break Kumho MX in.
Old Jun 1, 2004 | 04:06 AM
Jasonoff's Avatar
Banned
I drove nearly about 500miles then hit an auotx... they are broken in now for sure. Getting an alignment done on friday
mr 280z again
16
Aug 30, 2010 09:18 PM
RUCrash
Nov 26, 2006 07:26 PM
2005S2000
Jul 18, 2005 06:33 AM
TwistedS2k
May 1, 2005 02:17 PM
