Tire presure problem
hi Guys and girls,
I have a question. I recently bought a Honda S2000. a problem with that is that the standard wheels are not underneath it. the wheels that are now under it are: 225/35 ZR18 87Y XL. the standard tire pressure of the OEM wheels is 2.2 but I have no idea what tire pressure I should keep with these wheels that are now underneath it. I am now using 2.3 on all 4 tires. Do you have any suggestions or ideas what the best tire pressure is in this case for safe and sporty driving.
regards,
luka
regards,
luka
Seems like all the OEM size tires for the S2000 have a Load Index of 91 (1356lbs/615kg) per tire. An Index of 87 is only rated as 1201lbs/545kg).
My guess is the lower rated tire will need a couple psi more pressure to perform well so 2.3bar is as good a guess as any. Keep an eye on tread wear in a few months. It's possible to check the contact patch by driving thru a film of wet pavement and observing the wet print and noting if it's even across the tread.
-- Chuck
-- Chuck
2.0 to 2.4 bar (30-35psi) range is gonna be fine, I'd start in the middle of that. I would not "chase" pressures outside of that range based on wear patterns which are often more dictated by toe settings. Which should be set nearest to zero front and rear for best tire life and hanlding. IMO...
Not a question of supporting the weight of the car as passenger car tires can always support more than the car weighs. Without getting out of my chair I'm guessing the OEM tires are rated at a maximum of 1356lbs at 50psi (fifty) yet we run them at 32psi for a compliant ride and getting the contact patch where it should be.
Anyway what's a couple psi between friends?
-- Chuck
-- Chuck
dr.darkness
Nov 15, 2007 12:57 PM
2Ting
May 21, 2003 01:13 PM
