Tire size for 18x8.5 +45?
Wondering if it's a good fit to put 245/40R18 all around on 18x8.5 +45 all around? I know it'll take some rolling and bumper tab relocation. But will it fit on our s2k? Plan to do some track days as well. I use to have a set of rpf1 17x9 +45 all around and didn't rub until I hit a really big bump or full cranked turns. Thanks in advance.
Got it. Thanks for the info everyone!! Was gonna get the 18s but found a set of 17s that I really want. Only problem is the rears are 17x10 +50. Fronts are fine. Same specs as my old rpf1. Would I run into any clearance issues on the rear after bumper tab relocation and roll?
Originally Posted by 1nate7' timestamp='1426334572' post='23539738
17 x 10 +50 should be fine as long as you don't go wider than 255/40.
Awesome!!! Thanks again everyone!! Hoping I can pick up the wheels come Monday!!! Car's been sitting for over a year due to job relocation but now I'm back home and want to drive again!!
17x10+50 is actually a really excellent size. wheels that wide are hard to find in 17s with high enough offsets. +1 to the 255. if you roll and a slight pull of your fenders and you have more room- maybe down the line you can try fitting a 265 or a 275.
nice score
