tire size help
I agree with megaspawn, just run factory size tires, it will look good and you can stay close to UK spec alignment. They wont stick out, just look nice and flush. More aggressive then stock but not stupid looking.
i personally think that 255 and up is overkill for a DD S2000. the thing only weighs 2,800 pounds and is putting down 200 hp to the wheels on a good day.
Originally Posted by s2000maniac' timestamp='1347319299' post='22002256
and those sizes i would not rub? do you know how much it would stick out? or would it be flush? thanks
Originally Posted by 2000ths' timestamp='1347323294' post='22002412
[quote name='s2000maniac' timestamp='1347319299' post='22002256']
[/quote]
the OP has an AP1 so factory sizes are 205/225. and yes, 2,800 lbs is a relatively light car. i've run 205/225, 215/235, 225/255, 225/245, and 235 all around. all combos on the street and some at the track. the only setup i don't recommend is 205/225 unless you just commute on the freeway. and if you don't track your car you shouldn't be driving it in a manner where you are losing the back end on public roads anyway. i've run 215/235 at the track and it performed great while pushing the limits of the car(cornering, braking, accelerating). assuming you have decent tires then 215/235 should serve just fine on a DD.
Originally Posted by s2000Junky' timestamp='1347323910' post='22002443
[quote name='2000ths' timestamp='1347323294' post='22002412']
[/quote]
[/quote]
I think you would be quite impressed with what some real size rubber does for this car.
