WHICH TIRES?
Old Mar 16, 2007 | 02:50 PM
METATRON's Avatar
Default WHICH TIRES?
I am trying to decide between BFGoodrich G-Force Sport and Bridgestone Potenza RE750. Both have 340 treadwear. I have used the BFGoodrich before but was wondering if anyone can compare the two. Also, I am running 17x7(f) and 17x8
Old Mar 17, 2007 | 05:04 AM
METATRON's Avatar
Old Mar 17, 2007 | 05:27 AM
CaptainMike's Avatar
Have you read the forum stickies? Regardless of which tire you choose (I have run the 750's and they aren't bad for a 340 treadwear tire, though they don't last even 2x as long as the stockies). IMO you should be running a 215/45/17 and 245/40/17 with your setup assuming your offsets are good.
Cheers,
M
Old Mar 17, 2007 | 06:53 AM
negcamber's Avatar
with the tire size Mike recommends.
I've never run the 750s...but wonder why you would not run the oem RE050 for the ap2 since they will fit the wheels you have on your ap1.
Old Mar 17, 2007 | 12:14 PM
METATRON's Avatar
I see. My offsets are +47 all around. How would the RE050's last twice as long with a 140 treadwear rating though?
Old Mar 17, 2007 | 04:49 PM
What I meant to say, was that you'd think the RE750's would last more than 2x the OEM RE050's since the treadwear ratings are 340 and 140 respectively. but in my experience they lasted about 1.5 times the RE050's We'll say 12K or so for the rears vs. 8K with the OEM's (RE050's)
Old Mar 17, 2007 | 08:52 PM
METATRON's Avatar
Oh okay. I see. So I should change my tire sizes for sure?
Old Mar 17, 2007 | 09:29 PM
yumyumdimsum's Avatar
well i ran them both...my pick is the bf goodrich....im running 255-40-17 and 225-45-17.....there cheap off of tire rack.
Old Mar 17, 2007 | 11:26 PM
METATRON's Avatar
thanks
Old Mar 18, 2007 | 06:32 AM
As for the size I'd definitely go with stock AP2 sizes 215/45/17 and 245/40/17 any wider though and I think you'll possibly rub with those offsets.
Good Luck,
M
